Creating 2D symbols 18 Feb 2017 09:53 #2708
I have sent the Video to your email address some minutes ago.
Sorry
Creating 2D symbols 17 Feb 2017 23:00 #2706
  • Kathryn Deane
  • Kathryn Deane's Avatar Topic Author
Tx Thomas, but I can't find the attached video?
Kathryn
Creating 2D symbols 15 Feb 2017 08:17 #2701
I assume that you double click at the same mouse Position when the software expects a rectangle consisting of two points with a distance between first and second corner.
I have attached an archive with a short video demonstrating the handling, including the error message you get. Once inserted, the Picture should be scaled either in its property dialog or via context menu. The Video shows both options.
Kind regards
Creating 2D symbols 14 Feb 2017 15:07 #2700
  • Kathryn Deane
I've been following the tutorial on creating symbols, but can't make it work for me.
I can do 2D & Layout > 2D drawing functions > Insert bitmap > Rectangle > OpenImageFile > Select image OK. Then it takes me back to the environment where I draw a rectangle and . . . nothing? Except that if I click or hit return, I get an error message: "Validation: Invalid rectangle size (0.0)."
I'd be grateful for your help.
Many thanks
Kathryn
Time to create page: 0.148 seconds
